Hayman Reese WDH, which length springs ?
billykidd
86
36
Hi
I've read every post I could find on WDH, but I've one question. We have a 16.49.1 Outback, with the jockey wheel on the outside of the A frame. So what length springs should I be looking at, the 28 inch or 30 inch ?
I realise it would be easier to go to a dealer to have it fitted, but this would increase the cost more than I consider a reasonable amount.
crackacoldie
2,597
3,806
Newcastle NSW
Measure the length from the tip of the coupling to the far edge of the jockey wheel clamp. From that measurement, you will be able to determine which length bar you will require.
Bmhdg76
769
516
North Lakes, Qld.
@billykidd, did you get your van from Bne Camperland? If so are you a VIP member? They give it for 12 months when you purchase through them. If so, they sell the Hayman Reese bars cheaper than my F-I-L can get them wholesale from the supplier.
Not sure if they would charge you a fitting fee but I believe not if you have bought it through them.
BJ.
billykidd
86
36
Thanks, yes did purchase from Ben camperland, but almost 5 years ago, so no longer a VIP. . seems speedy towbars are much cheaper to buy from also at present in brisbane.
millers
282
246
@billykidd If you are worried about the jockey wheel interfering, consider using the following sequence. Connect van, wind jockey wheel up (lifting rear of car and front of van), connect WDH bar opposite jockey wheel, lower jockey wheel and remove, install second bar.
The theory is that the first bar is easier to install as the jockey will has done some of the lifting. The second bar is easier to install because the first bar is taking some of the weight.
On mine once the jockey wheel is removed there is no interference. The spring length should relate to the ball weight of the caravan.
For HR (from http://www.haymanreese.com.au/products/weightdistributionsystems.htm)
Understanding your trailer ball weight is the starting point for know which Weight Distribution System you need. Use the table below as a guide.
Ball Weight (kg)
Appropriate system
0 – 80
Mini
80 – 135
Intermediate
135 – 275
600lb Kit
275 – 365
800lb Kit
365 – 545
1200lb Kit
Hope this helps.
Steve
Roadkill
55
32
SA
Evening all. Have just picked up an 18.57-6 along with a HR WDH. Have a Slight problem where the left bar interferes with the jockey wheel clamp. Have any others out there had a similar issue or come up with a simple solution?
Thanks,
Roadkill
Moxley23
35
9
ACT
Can you show us a picture? I've got a standard length draw bar (2013 model Expanda) and 30 inch spring bars (HR) and no problems with the jockey wheel clamp.
hamish22
742
641
West of Newcastle
www.grmotorsport.com.au
Thanks,
Roadkill
Did on my old van and I got a guy to remove wheel clamp and weld new one to inside of A frame! Problem solved!
Roadkill
55
32
SA
2,346
g'day Roadkill
Who set that hitch up? looks like you have the standed model van non Outback
those bars need room to move slighty at the chain end they look way to close to drawbar.
I have Outback standard drawbar, bars dont sit anywhere near drawbar and can get the jockey wheel behind the bar just, though usually take the bar off first, bars also sit very low unfortunatey.
crackacoldie
2,597
3,806
Newcastle NSW
You could try tilting the head of the WDH away from the car a fraction, so you can add a link or two extra on the chain end, as @Bushman sys, the bars are too close to the drawbar, not just the clamp, I would be concerned about them fouling as you turned.
Reactions: Roadkill
Roadkill
55
32
SA
Will try that plan tomorrow cracka.
Bushman, yes non outback model. I would have liked the outback for the extra clearance, but towing out from the driveway this morning wasn't a problem.
