Grandpa Gunna's 17.58.3 OB mods
Grandpa Gunna
67
107
Northern Tablelands NSW
First mod was to find 2nd hand rear bumper with wheel carrier to move the spare from front A frame, so the gas bottles could be placed inside A frame and up close to front of van for fitment of a Fiamma bike carrier. (Since removed)
Second mod was installation of 30amp Epever MPPT Solar controller and MT 50 Remote display as controller in cupboard under sink.
replaced Jayco 120w solar panel with 220w (this fitted Jayco brackets). plus separate anderson plugs for portable solar and fused battery connection under side of van.
19,992
I like the Epever mines a 4210N but all the info on the screen but I might even get a MT50 to replace the one from my old Projecta charger..............., Booties will start crowing now I'm sure............. Tyre rack and the whole lot look good, what else ??????
Reactions: chartrock
Grandpa Gunna
67
107
@Drover you'll have to wait, doing specialist run today and yes I'll have some things for @Boots in Action
Grandpa Gunna
67
107
It’s all very well having battery and solar power “in“ display, however not being able to see what usage was going out stumped me until I came across @Boots in Action well explained post on how to rewire the Setec load through your solar controller. (Thank you, Thank you)
I was able without to much trouble run the cable to the controller through the cupboards and bingo now have the complete picture of our loads. Being able to see the draw as you turn each load on is very informative.
I have the van permanently connected via anderson plug to controller to a solar panel on roof of shed when at home.
After a while I noticed that I appeared to have a parasitic drain happening, as even with everything off there was a draw on the battery happening. Pulled radio fuse, thinking standby load happening, but no difference. (yes have cheeked what fuses do what, typical Jayco!!!)
So one at a time, pulled all fuses. Main inside light circuit was the culprit, however lights were off, Fuse back in (lights off) parasitic drain showing.
Tried to track down if Sphere Wireless unit has any standby power draw. Couldn’t obtain definite answer from suppliers.
I set about resetting the Sphere wireless head unit Circuit 1 and the drain disappeared from the MT 50 display ( I’m not sure if this circuit had gone into what they call “Pulse” mode!)
Have not had any further problems.
I will have some solar and 12v questions as I set up to be more off grid for longer, currently 1-2 nights. (although 3 females (2 teenagers) vs 1 male, its going to be battle)
(Avatar is taken at Lara Wetlands Barcaldine I would have happily stayed longer but not set up to do so).
19,992
Just as long as you dont run the regulator to battery thru the Setek all should be good...... I did find some light wiring had the switch on the earth side of the circuit not on the supply side, that could cause a drain of juice.
I often just shut down the 12v if not in use....
836
What a great idea. I need a 120 for the tug and the jayco one would do nicely
Edit: Just had a look at 220w on ebay. Found some with the same dimensions as the 120.... Not sure about that now
19,992
I found the 4wd superstore to be good in price and variety. Plus somewhere to complain to....they actual did what they say..
1,874
Glad the post was useful to you @Grandpa Gunna. A lot of members did not think it would work or that it would release the fire and smoke demons! You are another successful convert. That modification is especially useful for those that have the standard TPS1230 controller normally found in Jayco setups. But as @Drover has previously mentioned, it may take some work and perseverance to run the cabling through cupboards and across the van, but you managed to do it without too much problem. Great!!!
I am looking forward to being of assistance (if I can) on more solar challenges as you venture more off grid for longer periods.
Reactions: mfexpanda
Grandpa Gunna
67
107
The position of the water pump inside the van under the main bed has always concerned me, so last year when I made the decision to install a diesel heater I had to really start to think about how to move the pump to underneath the van.
I came across a thread (sorry can’t remember the name), however @Drover referenced his thread, in relation to moving the pump underneath on his 14.4. It gave me some ideas but I was concerned about dust and moisture getting into pump and protection from rocks etc.
An ammo box from S/Cheap caught my eye, it’s the larger one, the following photos show the end result. I don’t think it sounds any noisier, the box is mounted on thin rubber and I believe it is well protected.
A bit of rerouting piping to also make room for diesel install etc and while at it moved 3way tap to under van next to step for ease of access.
Having done this I now had the spot to install the diesel heater, (2.2kw from Tassie).
Yes, it was the case of measure a hundred times and cut the hole once.
I didn’t want to have a permanent tank on the van, so looked around and found 11lt tank and fitted quick disconnect fittings, which is placed inside the new tool box (small) which replaces the bike carrier on the A frame. We don’t have any ticking noise from the pump which is mounted on the frame under door side and fuel pipe runs to tool box.
The controller is mounted next to bed, bonus!!, don’t have to get out of bed to turn on.
While at Lightning Ridge for 3 days last year the heater was fired up (just to give it a go) and I found even sitting outside under awning you can feel the warmth coming out the door.
19,992
Very nice mods sir, I like the 50cal ammo box idea I didn't think of one of them when I did it on my 14.44 they are a very useful box to have for many things.....Not being picky but i would put some insulation over my water pipes where they pass thru the cross members, save them chaffing if they flex at all, just clear plastic pipe does the job quite well, I have put my water lines in old pipe insulation and flex conduit, saves any chaffing and from rock hits... If your water pressure and HW temp plays up throw the tempering valve in the bin.............. while they are a good safety device for kids, I'm dubious in a van especially a small one, if your going to burn yourself on the HW tap then hand in your licence I reckon... (incoming now I suppose)
Youv'e got a kink on one of your lines at the tap too...... If tap craps out the Pope garden irrigation taps work well 2 for $6 last I looked.
836
I did something similar by mounting it directly under the old location to reduce pipe rework. Saves heaps of storage space. Has removable ends for easy access. I also removed the tempering valve and get better hot water to the sinks
I also mounted the heater (aren't they the best!) under the floor using the same method. The pump is now in a different spot to reduce noise and the chux is acting as a fresh air inlet filter as it draws 50/50 from inside/outside
19,992
Thats much like the box I made for mine @jazzeddie1234 a very tidy mod as well, I slid my fuel line inside some 5mm clear tube just to give it some protection and insulate any pump noise.............
Reactions: jazzeddie1234
Grandpa Gunna
67
107
Thanks for mentioning the kink @Drover I'd thought I had fixed it, "something called memory I think."
Your comments re tempering valve are noted. I do want to get underneath and have a good look at all plumbing, as it is usual Jayco standard
Grandpa Gunna
67
107
Replacement pipe has arrived for the plumbing
One of the many lessons you learn on this caravan journey.
Always release the pressure on hot water pipes before lying underneath and disconnecting john guest fittings.
Local big green shed didn't have 13mm taps (can't get them been out of stock for weeks)
In Armidale yesterday they had boxes of them.
Finish the plumbing and I might be lucky to get a weekend away before school holidays, found a spot on the ranges 80 ks away that looks good.
Lozza T
157
204
53
The position of the water pump inside the van under the main bed has always concerned me, so last year when I made the decision to install a diesel heater I had to really start to think about how to move the pump to underneath the van.View attachment 66277
An ammo box from S/Cheap caught my eye, it’s the larger one, the following photos show the end result. I don’t think it sounds any noisier, the box is mounted on thin rubber and I believe it is well protected.View attachment 66278
View attachment 66279A bit of rerouting piping to also make room for diesel install etc and while at it moved 3way tap to under van next to step for ease of access.View attachment 66281
Yes, it was the case of measure a hundred times and cut the hole once.View attachment 66283View attachment 66285
I didn’t want to have a permanent tank on the van, so looked around and found 11lt tank and fitted quick disconnect fittings, which is placed inside the new tool box (small) which replaces the bike carrier on the A frame. We don’t have any ticking noise from the pump which is mounted on the frame under door side and fuel pipe runs to tool box.View attachment 66284
I like the heater mod. Can ask where exactly you got it from?
Grandpa Gunna
67
107
Hi @Lozza T diesel heater from Dieselheat Tasmania for basic kit and some eBay suppliers for other bits and pieces.
Heater a bit more expensive than eBay suppliers but like idea of Aussie support.
It is Belief 2.2kw, a 5kw would diffently be an overkill even with poptop.
Grandpa Gunna
67
107
4 day long weekend for mates surprise 60th in Wellington ( NSW), Diesel heater worked overtime, I now have to trace tik tik noise (didnt have it before) unsure if something has moved while traveling or cable tie pulled to tight when replacing all clear tubing.
Free camp behind Sports Club at Coolah a top spot, 2 other vans there for night. A great Chinese restaurant at club.
Took a while for the wife to notice the installation of carpet tiles when loading van. The van is quieter and of course floor not as cold
19,992
Coolah is a top spot and damn it does get cool, the Tik Tok on my heater sort of comes and goes but now mine gets a bit of a howl up when on full revs but only if your outside........... so not a worry........ Ive been thinking about carpet tiles, gets bloody icy down Canberra way.
You might have a fuel line against the body somewhere its always a mystery when I try to find mine...........
Grandpa Gunna
67
107
I think I fluked the install because I knew about everyones problems re tik and was surprised how quiet mine was. I will go over all the line, it is in split tube and check pump mount.
Tiles from big green shed, to be fair to wife they are a good match for floor and she does have macular degeneration, but did say something felt different, luvs them though.
