Flanders 17.56-1 Mods
Paul75
163
67
Gippsland, VIC
Regarding max ball weights stated on the compliance plate, I am getting Jayco to change mine. I've got an 18.57-9 with an ATM of 2692 and a max ball loading of 218kg which is a whisker over 8% of ATM. I wrote to them (the dealership where I purchased) with my concerns. They spoke to the Jayco factory caravan planner who has agreed to change it. I told them I want a minimum of 280kg which they were happy with and it's currently with them getting changed.
Reactions: Burnsy
Flanders
158
105
Just North of Melbourne
G'day Paul, sounds like you know a bit about the subject, how do they decide the ATM and ball weight, I've never thought to ask anyone?
Paul75
163
67
Gippsland, VIC
Regards to the ATM; once the caravan rolls out of the factory completed and ready for licensing it is weighed. This is the tare weight which can be described as the unloaded weight i.e. it includes empty water tanks, empty gas bottles, spare tyre.
From the tare weight, it then depends what spec the van is to what the ATM will come out as.
- a single axle no shower model will have 300kg added to the tare to get the ATM.
- a single axle shower model will have 375kg added to the tare to get the ATM.
- a tandem axle no shower model will have 400kg added to the tare to get the ATM.
- a tandem axle shower model will have 475kg added to the tare to get the ATM.
So mine rolled out of the factory and weighed 2217kg (tare weight). It is a tandem axle with a shower so they add 475kg which comes to 2692kg ATM.
As for the ball weight; I'm hoping that after building caravans for a while they have figured out for each model where to put things to come up with a reasonable ball weight out of the factory to allow for a safe ball weight once it's loaded. Mine was 170kg from the factory which I think is ok and allows me to load a reasonable amount up front to get to the generally accepted 10-15% of ATM. So they don't decide the empty ball weight, they just weigh it as it comes out of the factory. As for the max ball weight, this one has me stumped! Considering all the differing max ball weights I've read on this forum and seen on my travels I'm pretty sure they don't have a way to work out the max weight. I imagine they use the weeks lotto numbers and rearrange them to come up with it!
Reactions: Flanders
Flanders
158
105
Thanks Paul, I can get my head around that. I also cannot understand how they come up with a ball weight, I thought the towing vehicle would have to be considered as part of this?
