Yep. They are sadly missing up bed ends.Want to run a few 12v/USB for ipad charging. put one up the main bed end for my CPAP as well
A question for the 22.68 owners, do you know if the solar junction box on the roof is above a cupboard?
They wouldn't upgrade the solar cabling size, so i can upgrade the wiring if above cupboard. If not I'll buy higher voltage panels
Thanks it will be good to see the photos. Exiting times going to pick up your van!getting mine fitted for 4 bikes early next week for hopefully Friday pickup of new van .. will take some pics for you
Thanks for the info on the racks, much appreciatedThey add a third rail in beyween the originsl 2 and then extend the rack to add the 4th rail.
I will post a picture after pickup for you.. Yes excited.Thanks it will be good to see the photos. Exiting times going to pick up your van!
So got them to check 12v on all bunks. great I do not have to do it
None main bed endSo one job for me
Battery under the bed and HWS/pump under dinette.
As we brought stock we did not have a chance to move things.. Would of liked a power point down bunk end of kitchen. Has anyone added one?
Thanks again @Shane Norwell I am building a list... Yes thought can get up from behind where the door is.
Just outside making room for the new van bye bye some small trees.
Thanks Shane yes did the tour thought that was easier for them to hiring a real sparky. Although wondered anything on that side I could take a split from. So you got a double adapter ran it up where the concertina door is and through the wall?Not sure if your aware of these so thought I'd chuck the link up, this is what the whole jayco 240v system is made up of so they're completely plug and play, no sparky required.
http://caravansplus.com.au/catalog/index.php?cPath=32_1060_962
Yep that's it mate, you'll find there's a junction down under the stove so too easy. There's a cavity about 500mmx100mm behind the door.Thanks Shane yes did the tour thought that was easier for them to hiring a real sparky. Although wondered anything on that side I could take a split from. So you got a double adapter ran it up where the concertina door is and through the wall?
thanks easy asYep that's it mate, you'll find there's a junction down under the stove so too easy. There's a cavity about 500mmx100mm behind the door.
We have the battery under the bed too however usually going to carry four bikes at rear end which should offset that. As for the power point down the bunk end of kitchen, yes we have asked jayco for one there so we can use a Thermomix. There are a few regs about where you can locate a power point in proximity to stove top, so it may be the power point goes inside the overhead cupboard.I will post a picture after pickup for you.. Yes excited.
There should be one in the cupboard next to the microwave. Could you use that?We have the battery under the bed too however usually going to carry four bikes at rear end which should offset that. As for the power point down the bunk end of kitchen, yes we have asked jayco for one there so we can use a Thermomix. There are a few regs about where you can locate a power point in proximity to stove top, so it may be the power point goes inside the overhead cupboard.
@Gilmorehappy
Not sure you saw on my thread although seeing I am back on a real computer here you go bike rack.
Can open it up for you tomorrow.
