Have finally had some time to put the 1st mod on the new Panda.
As we are heading north to some warmer weather, we are hoping to spend more time outside the van than in it, so 1st mod was to put an external LED strip light on.
Here are the steps taken...
Step 1: Remove the top fridge vent, locate and cut the wire running to the external annexe LED light.
Step 2: Crimp the external annexe LED wires back together, adding in the smaller wire to go to the LED strip
Step 3: Solder the small wires to the exposed copper terminals on the LED strip & check it works!
Step 4: Stick the LED strip into place - note the double sided tape most of the come with is useless. After removing the double sided tape from the back of the LED strip, I used (very sparingly) PASCO FIX - an industrial super clue. More on this product in another post. Replace the top fridge vent, making sure the LED strip wires are tidy.
Step 5: Turn on the LED strip and admire your handy work.
Cheers,
Rohan
Cheers,
Rohan
