18' Series External Antenna Points
NoWorries
806
1,344
Hey all
I am just wondering if all the external antenna points are connected and if so do they all work of the booster.
I am setting up the Sat TV setup and wanted to plug it in via the plug near the power inlet.
I am too lazy to take the cover of and test the points i'm hoping someone here has the answer
I use the same antenna inlet socket for Sat TV and it works fine but disconnected it from the booster and fitted the other end straight into the back of the set top box (Booster not required). The wineguard antenna is now hooked in through the booster.
19,906
I just plumbed a thru wall socket for the Sat TV then all the connections stay hooked up and only have to set up dish and plug in............have found if I use the analogue aerial output on SatSTB and plug it into normal aerial socket in van I can run the picture to the TV in annex without dragging all the sat gear outside.....................not a brilliant picture though.
Hey all
I have separate circuits, wineguard independant to external point. I have 2 inside points, one for the Wineguard and one for the external, so no power to my external
