14' Series Expanda 14.44-5 OB Purpleline movers
Nicole&Dave
Hi. Does anyone have a 2017 14.44 expanda outback with purpline movers on? We’re installing ourselves to save some $$$ and debating if it should go infinitely or behind the wheels. If you’ve got any pictures of ur install to help that’d be great.
Nicole
1,874
Nicole
Hi @Nicole&Dave , do not know about the purpline movers on an Expanda, but have seen the movers on another van and the metal wheel apparatus to work on the wheel was definitely BEHIND the wheel itself. Mind you this was on a single axle van. If you had a dual axle, I believe it would have to go after the rear wheel so as not to get in the way of the front axle assembly. Only what I have seen and not necessarily the way to go. Have a look on Ebay under van movers and you might get a picture to give you some ideas of the set up.
1,874
Nicole
Again @Nicole&Dave , have a look at the forum on Caravan Movers started 23rd June 2014. It has all the info you need supplied by members ofthis forum some time ago. I just looked at "What's New" and there it was only 3rd or 4th heading. There is even a video which @Simon mentions and a pdf from @Macropod. Hope this helps.f
19,997
The manual doesn't really say I suppose it depends on if it will fit and just use the correct harness........ I would be a bit worried on a 14.44 of tipping the scales with an extra 70kg bolted on.
Reactions: Marv_mart and MDS69
