DUST -what dust
BUSH PALACE
1,534
1,111
LOBETHAL S.A
Thought Id give this ago , positive pressure system , just bought off of evil bay a bilge blower rated at 130 lpm , vent and flexible ducting to try and evict the dust when on outback roads .
Fitted the fan behind the a/c above the fridge with the outlet above the stove , picking up outside air from the top fridge vent .
And what a test up to the Corner in a couple of weeks
Moto Mech
582
1,106
Mole Creek, Tasmania
Im gunna do this but im fitting a external filter to van some where, something like a older hilux airfilter box so its sucking in clean air. Should work great I think
Colsar
701
868
Mornington Peninsula
Looks good, inlet filter advised, but one question , most bilge blower are rated for temporary use only, how's it go running for over an hours drive.
Bilge blowers usually run for only a few minutes.
BUSH PALACE
1,534
1,111
LOBETHAL S.A
Worked a treat until the way over to Farina the main power wire to the switch dislogged itself and started sucking in dust , so now mk 2 is on the drawing board ...
Reactions: Chooky
alexvk2
85
72
Have yet to try long trip ..next month....however the main heat from the gas burner is insulated and has its own separate flue.I have also increased ventilation to the cooing fins with a compuyer fan at bottom vent intake.Do not anticipate any heat issue with blower as it is designed to run continuously in an engine room on a yacht and back of fridge only gets a bit warm.
