16' Series Dust Proofing for the Outback
GregW
72
81
crackacoldie
2,597
3,806
Newcastle NSW
Hi
I did this mod before we went to ayers rock over the great central road, 1200km of dirt, got hardly any dust in the van, with i could say the same thing for the outside. Its a 139cfpm fan and filter the pumps air into the van, does not matter if you are in a convey etc as the filter stops the dust, also great at slow speed on bad roadsView attachment 19285
Where abouts is that mounted, a great idea that I was thinking of!
BUSH PALACE
1,534
1,111
LOBETHAL S.A
Hi
Where did you get it from GregW , it looks like it at the back of the fridge so where have you the outlet fitted ?
GregW
72
81
I cut a 50mm circular hole in the imside wall and put a vent cover over it, i bought the parts from a marine supply shop, i think its called whiteford marine here in wa. The air filter is just a sports filter from supercheap. Just make sure the neck is 50mm etc to fit over the fan.
Reactions: blacky
S&P
219
184
Yarra Valley
www.sefiiraforge.com.au
Hi
Thanks Greg, that's an awesome idea! Yet another one for the must-do mods list.
Cheers, S&P
Reactions: blacky
3,035
3,405
Yeah the positive pressure through the fan is a great idea. Our first Expanda had a positive pressure vent on the roof, didn't someone on here make one fit a later Expanda?
Re the rear bed lid and pop top getting dust in. I have found that I had to adjust the catches a fair way till the sealing rubbers touch and actually seals! This has kept most of the dust out.
3,035
3,405
Whitworths perhaps? They are a marine suppliers over here?
crackacoldie
2,597
3,806
Newcastle NSW
I fitted a positive pressure hatch (Scupper vent) to mine before the trip to Cape York and it helped dramatically, once I found the leak underneath.
Reactions: blacky
blacky
630
680
Townsville QLD
@GregW thats awesome mate, that is definately on my to-do list. Great thinking using the fridge vent space too - i guess not only is that a neat, tidy spot where it won't be in the way at all, it also will provide extra air flow through the fridge vent space to allow greater heat dispersion. I like it! Did you pinch power from the external 12v power source?
ROnEM
650
356
Macedon Ranges, Vic
Reactions: blacky
DaveS
215
183
Thats a great idea with the fan, i would take it just a tiny step further and connect it to the hot wire on the car with a latching relay, that way it only runs when your towing the thing down the road, pull the power straight off the fridge 12v supply circuit, wire a relay so when it "sees" current on this line it closes the relay to send power to the fan, a small switch on the current sensing line could turn it on/off without the switch needing to handle full current load
Reactions: blacky
Brad
2,645
723
Rowville, Victoria
Have you seen one of those fridge switches? Couldn't you kill two birds with one stone if you added in the fridge switch to this solution? Or is a fridge switch a latching relay?
DaveS
215
183
fridge switch is a tremble switch, while your getting bounced around it closes and lets current thru, stop moving and it opens, a latching relay uses the supply current (the car) to pull the switch closed to allow more current to flow without overloading a switch. I use a latching relay on a lot of "fix me please" jobs with no setek etc. to allow the fridge to run off the car without using a diode (which has a voltage drop) to prevent power feeding back into the car. without some sort of protection a poorly wired car can try to use the van house battery to start the car which can cause high current draw thru wires that can't handle it (so they melt!) also used bridge rectifiers (4 diodes stuck together) to allow the car to charge battery and run fridge off single supply but prevent house battery from running fridge.
note: these thing aren't really relevant to the jayco's as they are sorted out to do this (well ... they should be!) without me wasting brain cells on them.
Reactions: blacky
GregW
72
81
Yes i cut it into the power off the car and put in a water proof switch. That way it can only get power from the car when driving
Reactions: blacky
