Hey
@boots33 and
@navmatt
Thanks guys that is great to know. Boots33 see the image attached for the actual wiring diagram of the relay that i got with the ctek.
Navmatt, im not sure what you mean by if you have no no solar just wire directly to the solar input??? I would have thought, if no solar than no need to wire in the relay and just leave the solar one empty or do you wire the ignition straight into the solar input?
again thanks guys.
Ants
Thanks for the pic Ants. I will have a look at their web site later and see if i can get more info. But for the
moment here is what i think has happened.
To disconnect your service battery from your start battery when the engine is not running the d250 uses an internal
VSR (voltage sensing relay) circuit. This will disconnect when the voltage measured on your start battery side drops bellow a pre set limit. I don't know the setting but for our example lets say 13.5v. Now dumb alternators usually run at around 14v so the ctek will have no problems and connect as it is meant to do. Smart alternators however will more often than not sit at around 13v so your ctek will think the engine is not running and disconnect, leaving no charge going to your service battery.
Most modern VSR's allow you to adjust the cutout voltage so you can set their threshold voltage lower when connected to a smart alternator. I have no doubt that we will soon see a new ctek that will have the same feature. Untill then if you have a smart alternator you will have to use their "work around" and fit an extra relay.
The solar input of the ctek is unlikely to have any sort of cutout so you will need to fit the relay (If you have a smart alternator) whether you have solar fitted or not. Otherwise your service battery will remain connected to your start battery all the time and you don't want that. Make sure the relay is switched by your ignition circuit as shown and not the accessories circuit and though they don't show it in the circuit a fuse will be needed in the supply line.
I must say i am a little disappointed with ctek's position on this, they have a product that appears not to be compatible with some modern alternators yet instead of marketing it so they offer up a kludgy work around which will severly impact anyone with solar connected.
