Not 100% sure if the right thing to do but I've set the unit to shutdown the fridge to shutdown when the tug's second battery gets down to 12.0 volts but still feeds the vans battery?
Reactions: skippy
skippy
935
793
Butler/Perth WA
Same here with a second battery in the tug via a Redarc BCDC and solar panel ready for a few cold beverages on standby. Same as you I never have to worry about warm drinks for the kids;) :biggrin::rofl:
Not directly Expanda related but to do with the tow vehicle..... Some others have posted new vehicles and/or fitting out of much needed accessories ;)
After receiving an early birthday present from Mrs Dagree I decided to fit it yesterday... Took about an hour longer to fit as per said on the instructions but we won't go into that OK :crazy:
The "before" shot!!!!
After measuring and sizing up 3 or 4 times the pilot holes were drilled!!!
Now the sweaty palms and shakes starting :crazy:
The worrisome part done :thumb:
All done :)
Matt... The sweating really started after I realised I used my 89mm holesaw and not the 95mm one :cower:
But half an hour later with the help of the dremel and a small grinding bit all was good :encouragement:
Was given a small amount of silicon from the supplier.... Supposed to be what they used so hopefully all OK!!!!!
