Coast Runners Outback Expanda 14.44.2
Coastrunner
414
126
South Coast NSW
Final job:- Putting a Hasp & Staple onto the pole carrier. Attached with rivets.
This will prevent the cap vibrating off while driving and also keep anything from getting pinched.
Reactions: Burnsy
Coastrunner
414
126
South Coast NSW
Took a bit of time out today to make a set of roof supports. I had some on the old van and used them in strong wind conditions. At times the roof would come down so I used these supports for a bit of extra strength. I copied the idea off another down under member and used 15mm pvc pipe with 22mm rubber plugs from Bunnnings. I also went around each leg half a dozen times with electrical tape to keep the rubber plugs tight on the ends. All up less than $10 from Bunnings. I also have a couple of adjustable supports but think these are just a bit easier to attach.
Positioned on van.
