Hi Just wondering if anyone has or has had any experiences with the Clearview towing mirrors, in particular for 2012 Ford ranger. Any pictures would be good as well
I fitted a pair to our 2013 Ranger and am more than happy with them. With the mirrors they supplied a DVD with step by step video's which were easy to follow and took about the time they estimated to fit. Although they set it up so that you supposedly watch each stage and then pause it and do the physical part, in practice watching the whole thing and then doing it was a breeze. The only parts I had trouble with was the door internal panel plastic clips on one door preferred to pull out of the panel rather than the door itself. Then one connector to the electrics was a bit dodgy and needed a bit of help to seat in one terminal a bit further.
In operation they produce a bit more wind noise but easy to ignore but my window shields are rather poor fitting themselves and need attending to as some noise is from them. With use the sliding part is becoming easier but a bit of lubrication at times might be needed. Vibration of the mirrors is no worse than the standard ones.
I was a bit apprehensive about rear vision to start with as picking up our van in Adelaide and with some short SA touring and the run home to Darwin this was our first caravan trip. On very little of the trip did I feel that I couldn't see adequately behind the van. Between the 2 mirrors on each, and on one side or the other, I was mostly able to see the shadow of a close behind vehicle except around the middle of the day. Although a rear view camera will be fitted to the van, it's no where as essential as I had at first thought.
Apparently some people refit the standard ones when not towing for a while but I'm leaving ours on, mostly just to get used to them but also because I don't think that it will do the door clips a lot of good trying to prise them out multiple times.
Sorry but I don't have a picture with them extended at the moment.
Regards
Phil
