Burnsie's Unexpected 17.56-2 Outback
burnsie
824
1,857
Another safety mod to add to the van........ thanks again @TRAKADU will let you know how the install goes
Reactions: bigcol and dagree
burnsie
824
1,857
Called past Caravanland to check up on the van and it looks like most of the accessories are installed.....
Unfortunately the guys have installed the storm cover strips on the outside, but I am sure they will still work fine..
I did notice however that the tyres are LT's which is great...
The installers have done a great job though especially as they have installed the internal speakers at the ends, instead of in the sitting area, gave it a quick test....sounds good.
Just a few more changes so hopefully ready in the next week or so
Getting the Prado sorted next week with the TowPro and electrics and we a nearly there......:)
Reactions: Bluey and dagree
Looks good @burnsie and guessing the anxious feelings are setting in. We had to wait two weeks and that was bad enough!
The bed end cover strips were originally designed to go outside so guessing that's why they fitted them there but others have found different options (All too late as I installed ours before hearing of the underneath option) but as long as they do the job.... and ours do :)
Still contemplating putting a stereo in ours and was going to fit the speakers in the sitting/dining area but now seeing the speaker near the bed might go down that track.... Listen to the Footy while laying down ;)
Reactions: bigcol and burnsie
MDS69
735
806
Looking good.
Our sail track strips are on the outside and so far no issues. They were fitted in the factory I believe and not the dealer.
Reactions: burnsie
Yep as @Cheyne78 said Ledge will be perfect if not busy. If busy will make it a good test for you as the roads through the park are a bit narrow.
Kuringal would have been ideal...... Just drive around, find where you want to set up and just park anwhere ;)
Reactions: burnsie
