Hi does anyone know if the supplied DC charger can be left permanently connected? Is there a risk of over charging?
I'll let you know what the instructions say when mine arrives @JaycoQ ... Got posted this morning!
I tried to charge mine using the short lead on the unit with several 12v units I have but it didn't work which made me remove the battery and charge it with the motorcycle trickle charger . I think using the 12v units didn't work because they are only 12v max and the one that should have come with the brake away is 15v ?Spoke to the service guys today and was told the unit can be left permanently plugged in. The adaptor will step down to 12v and the unit itself has a regulator.
Thanks @dagreeI'll most likely do the same removing the battery is a pain . I might see about fitting a 240v PowerPoint in the front boot near the brake away unitI looked around locally and could only find 15V ones that were over 1Amp..... Towsecure site said that they should be 15V 1Amp maximum so that's why I ended up ordering the original online.
Yes it looks like it to me
@achjimmy ours failed after the first trip and I couldn't charge it so ,mrsmfexpanda bless her , rang the dealer we bought our van from and long story short we bought a new battery and they reimbursed usMine didn't hold a charge for 3 days so I guess it's $&@(Ed? I am going to ask Jayco to explain it when it goes in for warranty in a weeks time![]()
