blueys 100 series
Status
Not open for further replies.
2,652
3,819
well got the cruiser back today no badge changes @mfexpanda or @Crusty181 it a cruiser nothing wrong no troubles just things need to changed to keep it going strong for another 20 to 30 years long after many Nissans have made there way to the crusher :behindsofa:
anyway 3" exurghst red back ,,, rapid tunning module which has given me 30 to 40 % more power 50% in some stages of speed especially around 100ks goes very good now heaps of power ,,,,, full rebuild of front diff cv joints seals rubbers and everything that goes along with that ,,,,, EGT gauge which is very good digital instantaneous readings im told can sit on 550 degrees all day but don't go over 590 if it dose slow down and it will go down even better stop and have a break its fitted in the ash tray very nice and yes you can watch it increase with power then drop back as you back off very happy I got this one ,,,,,, full service changing all oils and filters ,,,, a first stage fuel filter so now I have 2 which is also very good for those far away servos so here's a few pics of the EGT gauge and my huge pipe it has a very good note to it now I can now give it to my son when he turns 18 hes 19 months now hope he wants a cruiser you can see temp at 101deg when I got home at idle through one in of my anode which I did the other day IMG_3222.JPG IMG_3223.JPG IMG_3225.JPG IMG_3227.JPG IMG_3229.JPG IMG_3213.jpg
lets not get too carried away, slagging the Nissan's, just cause you got your Toyboata back -
(you know why they call them Toyboata's dont you.........????? they float very well when in water..............)
I will let you off because of your excitement @Bluey of getting it back in 1 piece
2,652
3,819
booked in for more mods on the 22nd of this month just before we go away cost of next mod $1600 ??????????? rack it up !!!!
I must say its going very well fuel usage is very good
2,652
3,819
So do I and the one I just bought didn't fit. The supplier has showed his hand straight up by declaring its my fault they gave me the wrong one o_O
":director:In the red corner Crusty the Clown :boxing-25: .........
Its not one thing but many
You should know that the customer is always WRONG!!!!!! (In the eyes of the supplier) o_O :argue:
I take it all back .... they've touch base today and they'll "wear the loss on that one" ..... no sure I agree with rationale, but I not fussed with whys or wherefores, or how its been justified. If their happy thinking they they've done me a favour, thats fine by me.
Reactions: bigcol and dagree
2,652
3,819
getting ready ,,,,,,, today fitted the p2 controller and finished the CB I challenge anyone to find it its in the best spot ,, booked in for Tuesday for the next spend
2,652
3,819
all better now with theseIMG_3285.JPG IMG_3286.JPG iron man shocks 40 mm tube foam cell and air bag man air bags with Kevlar sleeves can pump up to 50psi but wont need that much front sits a bit high now do I get new back springs to lift a bit at rear or turn down my torsion bars which are maxed out he says which will bring front down but less room for bottoming out ??????????? 10 to 20mm should be ok to bring it down a bit or let it settle in and see how it goes
Status
