These took five minutes to put on today for a ride by the river. (And one is a tandem) Out of the way. Cheers.
Thats the worst bit when you go to the trouble of taking them and the kids dont use them and ride their scooters around.meh, think i'll just buy the kids roller blades..
Hi Matty, I have the same car and worried about exceeding towball weight with can. How did you get around it? Any alterations to the car. Van load and jeep I cannot put more than 225 kg on ball even though it pulls 3500 kgs. This has been a 2 yr saga for us.
I have the typical 4 bike carrier off the tow ball mount (which can be lowered down by lifting up and pulling forward) but I don't use the panda rear bed so it stays in place most of the time. A benefit is I can swap the bike rack between the car and van if heading out for an adventure elsewhere...
Hi,@Cheznick5 If you have down ball weigh concerns, why not put the carrier on the back of the van? I have attached a photo on here of what i did. Needs a little more work to fit to the bar initially, but worked well and can pivot out of the way to open up while remaining loaded. As it runs a hayman & Reece style receiver it goes on the car as well it changes over in Seconds if you are away with the van and then want to take the car and bikes somewhere else.
If you want to run a box on the front, the tire can go under the van which is what i did. Let me know if you want more info.View attachment 27846View attachment 27847
We are looking at solutions for a storage box and bike carrier as well, your solution looks quite good. Just wanted to check though is yours and extended draw bar or normal? Do you have to take the bikes off to drop the bed end if you stay attached to the car. Also wondering about dimensions on your box to see if it may meet our storage needs. Thanks for the help!@Izzya123 Ours is very similar to Matty4's. Works really well and no problems with the turning circle...
