I have recently (about 10 months ago) installed a Fullriver 120ah battery as my main one and moved the Jayco generic battery as the second one. These are generally charged by 2 x Solar panels on the roof which generates plenty of juice to charge the dual battery system. However, recently I washed the Panda and put the cover to keep it away from the elements. This morning I opened the door to find out the main battery is totally flat (I mean it shows 5.5V) and the Solar Regulator display unit inside the van constantly beeping. The 12V system has also been cut off so there is no 12v power in the Van. I quickly plugged in the 240 system to charge the batteries hoping it is not too late. Did I stuff up my Battery??? or will it come to life??
By the way, my second battery displays 12.5V. (I thought if they are connected on parallel basis, it should complement each other). I have couple of small units connected the likes of CO/ GAS monitor which only draws a small current.
