Hi everyone we have bought a new 14.44.5 xpanda and have had it for one month now and had our maiden trip 2 weeks ago everything went great ,very happy with the way it went behind the car but thought I would check the ball weight using the house scales the
way its been explained here on the forum and ended up with a very surprising result ,the compliance plate says ball weight is 137 and a max of 176 which is no worry as my car has a 150 - 200 ball weight depending on how much weight is in the car but when i weighed it ,it was 220? and I have done absolutly nothing to the van since we picked it up ,surly jayco would have weighed it with the two gas bottles and spare tire that sits on the a frame when it left the plant? It does have two water tanks one in front the other behind but I would be surprised if that adds that much extra weight , to make sure I weighed it right I stood on the scales at the same spot and *Try posting a bit more so your post isn't boring* it worked out to my weight has anyone else had this problem? thanks
