Found this.
Not sure how sturdy it would be though..
http://www.trailmax.com.au/caravan-accessories/3-expanda-bike-rack.html
Thanks @pradoNumber plate is still visible with bikes on. Here is a picture with bikes off but gives you a idea of clearance.View attachment 17496
Thnx Prado. Dumb question, but I assume the 50kg capacity includes the rack weight also...All still good with mine. Only thing is make sure you tighten the securing nut tight. No need to strap it that I can see. They are actually quite a well built unit and seem to do as advertised. Make sure that you dont overload it on weight though.
Yes certainly does.Thnx Prado. Dumb question, but I assume the 50kg capacity includes the rack weight also...
