I connected trailer to car and nothing in van works and yes the plug on car has power to it van has a battery system
If you have a battery fitted in the van then the lights etc. should work without the car being connected. Have a look at
this post to see what the setec looks like. Depending on how it has been wired the fridge may only work when the car is plugged in and running. The most common way for jayco seems to be to run the 150ltr and up fridges from a separate line.
where do I start searching for problems
First steps to take are:
Make sure the main switch is turned on. You can see in the post i refer to above they most often look like a normal house light switch.
Check for blown fuses in the setec. There are fuses for different circuits and a main one (usually marked as Batt) the main one will stop everything from working if it is blown.
Check for blown inline fuse at the van battery. Locate your battery and find the inline fuse which is usually positioned close to the battery somewhere. if this fuse is blown nothing will work either. When my van was delivered there wasn't even a fuse in the holder.
Make sure your van battery is not flat. The setec will automatically disconnect the battery once it gets below 10.5v and nothing will work.
We have had several members that have had faulty main switches so if your fuses are all ok then that might be worth testing. I have also seen bad/loose connections on the back of the setec but if you are not confident with wiring you may be better off seeking out a sparky to check it out.
