I bought one of these . it the second one I,ve owned
The unit also automatically disconnects the battery if the terminal voltage drops below the selected Voltage (user selectable), and then reconnects it once it is charged again.
It features an LCD panel that displays battery voltage, the solar panel voltage and the active charge mode.
"Unlike other regulators, you can see the true status of the charging system at a glance".
Features
*User adjustable charging voltages*Suits Wet or Sealed Lead Acid, Gel, AGM ,Lead Calcium, Lead Antimony, Ni-CD, NiFe Batteries*Microprocessor control PWM (Pulse Width Modulation) for optimum charging*3 stage charge algorithms, Bulk, Absorption and Float charge with status on LCD display*Ampere Hour logging readouts in 3 sets, today and last 2 days*5-state LED indications of battery levels*Electronic overcharge protection and back current blocking to solar panel*Dusk to dawn automatic on-off with 10 selectable on-off programs*Adjustable battery low voltage level disconnect and reconnect for DC outputs*Battery reverse protection
Specifications:
Battery voltage: 12V
Maximum PV panel open circuit voltage: 26V
Continuous load / charge current: 30A
Maximum charge current (5 mins.): 35A
Maximum load current (5 mins.): 35A
Operation current (no load and PV): 15mA
Voltage across terminal (PV to battery): 1.2V
Voltage across terminal (battery to load): 0.6V
Electronic Blocking*: Yes
Battery reverse polarity protection: Yes
Overcharge & Over-discharge protection: Yes
Battery status LED indiction: 5-state LED Indications
Charging status indiction: 3-state LCD Display
Recommended wire size: #10AWG
Weight: 0.48kg
Dimension: 150(W) x 85(D) x 50(H) mm
Fuse: 40A
Operating ambient temperature: -10 to 50°C
Over temperature protection: Yes
Battery charging float voltage setting: Adjustable from 12.0-15.0V
Battery charging bulk voltage setting: Adjustable from 12.0-16.0V
DC load control mode ( For DC load terminal)
Low Voltage Disconnect(LVD): 8-16V
Low Voltage Reconnect(LVR): 8-16V
