Electrical 240v 90deg adapters
Paul
148
182
Ipswich
Hello fellow expanda clan
I have a question I am hopeing someone may be able to answer.
I have a Kogan 24" tv for the van. It comes with a wonderful 240v long plug that could back up as a stabilising leg for the van should I break one..
Because of this it naturally won't fit in the standard gpo above the bench.
As I was born with a lazy eye which has now spread to the rest of my body I was wondering if there is a 90deg 240 adapter available to avoid shifting the gpo or adding another one.
Could always get a short lead made too.
Has anyone seen such a thing?
Cheers Paul.
Seanm5253
65
106
58
Hillarys Perth
I use these and just use the top plug
Paul
148
182
Ipswich
The only problem with that is the plug is a power reducer. I think. But good idea all the same.
I ended up just getting some adapters that go up so all good now.
1756mick
51
168
Oh.. If the 240 to 12v inverter is in the socket then yes dumb suggestion. Could just run it permanent on its 12v supply? If it is a 12v TV
