Suspension 2015 Jayco 17.55 Journey Outback wheel brg numbers
BJM
485
549
Yamba
Anybody know what wheel brg numbers for this dual wheel van.Probably the same as an Expanda dual wheel out back.
20,079
Really need to have a Captains, depends if the axle is parrellel or not. I always feel safer to pop the hub and have a look at the outer bearing and pull the number then if its a parrellel stub axle the inner will be the same.......been caught out before by taking someones word.
BJM
485
549
Yamba
Its Outback 4 wheel JTech suspension ,previous owner just had brgs re greased etc didnt want to disturb them.Just thought a spare set wise .
I've got a set in my vans Murphy bucket, all Outback Jtech mk1 are the same components and 12inch Alkos. Im in the middle of repacking mine so I can have a look later (even check if my 6 year old spares match, ha) Jayco can tell you from the chassis number if you want to be confidently sure.
20,079
If I look in Big Mals manual it actually says what the bearing numbers are, I discovered this helpful bit of advice after I'd pulled the damn hub off to look, not expecting real info in the book.
@BJM
20,079
Cant make out the number, would have thought parallel bearings myself but there you go....
