POD,
Exactly how I have mine set up - works a treat as I have a LC200 with "Smart Alt" and two (2) factory fitted batteries behind each headlight, just connected with a "big" cable between them. My auto elec says they have to run two batteries just to kick the thing over!
After many beers, ideas and wiring plans, my auto elec and I finished up with the following:
For the purpose of the van and the Tekonsha P3 brake controller, all power is taken from the battery on the driver's side.
Brake Controller:
The P3 brake controller +ve is connected via 20A auto reset circuit breaker and 6mm cable to the battery's +ve terminal.
The electric brake voltage feed "blue cable" is again 6mm from the brake controller and feeds back to pin 5 at the 12 pin plug. The thin blue wire in the factory loom is not used, but not removed from the loom, just disconnected at the rear plug.
To charge the van batteries:
There is a twin core 6B&S cable running directly from the +ve & -ve battery terminals to the Anderson Plug at the rear. There is 50A auto reset circuit breaker and low voltage solenoid mounted near the battery. In the van is a CTEK 250S Dual DC-DC charger that is connected directly to the Anderson Plug to charge the 2 x 100AH Gel batteries in the van.
To power the 150Lt fridge:
There is a single 6mm cable directly from the +ve terminal on the car battery, via the same low voltage solenoid and 50A auto reset circuit breaker as the Anderson Plug.
This is connected to pin 9 on the 12 pin plug.
There is a 6mm earth from pin 10 of the 12 pin plug to the main chassis rail.
Voltage drop to the fridge is now only 0.6v and it keeps the drinks super cool.
Contemplating connecting it directly to the van batteries via a low voltage solenoid, but it works really well as it is.
To recharge the breakaway unit battery:
Pickup the 6mm +ve from pin 9 and loop a short 6mm to pin 2
To improve other earth lead:
At the vehicle's 12 pin plug, disconnect the thin factory loom white earth cable from pin 3.
Replace with 6mm and earth to the main chassis rail.
Off Grid:
6B&S cable connected from one of the van’s 100AH Gel batteries to a red Anderson plug at the front of the extended draw bar.
200W 10.4A solar panel to recharge when off grid and sunny.
2,500W (5,000W Peak) Pure Sine Wave Inverter connected to both batteries to run the express/cappuccino maker and other AC appliances as required. Happy wife = great trip
Red Anderson Plugs used so as to avoid accidentally connecting the wrong things together.
Have always driven with head lights on, even when not towing - Just habit!
Hope this helps others with some ideas.
Cheers,
Rohan
Brake Controller:
Off Grid:
Cheers,
Rohan
