17Triton's Starcraft 17-58-3 OB
17triton
3,717
5,438
Ballarat
Matt were you on dead motherless flat ground? The jtech not being load sharing slightest rise under a wheel and it will punch your ball wieght out? Mine loaded with some water in the rear hatch area full tanks the gen and weber is less than 200kg! The tanks don't add directly to the ball ie 50 kg of water does not ad 50kg to ball more like 25kg iirc, which you probably already know?
You are spot on Jim and I hadn't thought about that it was slightly down hill. That would explain a bit.Tanks had caps off but was dripping a little out still so wouldn't have had much in it.
Looks great by the way :)
Cheers mate.
Pauly
261
611
Oooooo nice !!!!
Got a big smirk each time you look in the mirrors I bet:D!! And perfect timing got the long weekend!!
Reactions: 17triton
peterg
785
2,292
warrnambool
c'mon @17triton you've had plenty of time, where are the mods and the photo's?????
MickL
66
115
SA
Does your toilet cassette hatch open with the awning rolled?
I'd be interested to know that as well as that was one thing I specifically specified on the contract and was told at the show by someone pretty far up the Jayco chain that the arms for awning should not cover the door and stop it from opening.
