G'day Guys,
With a new 17-56.2 Outback on order, I'm considering adding the Hyland Coupling to the list of options (if the budget stretches) I would love any advice or experience out there as to what works well.
A couple of quick questions:
-Does the Hyland coupling still work effectively with the HR Weight Distribution Hitches?
-At what point / angle do you remove the WDH bars for steeper angles?
-Is there any difference in the ride for Hyland vs Standard Coupling?
-Have you fitted them via Jayco or after delivery? (cost for Jayco vs Aftermarket??)
-Is the hook up time much different from the standard couling?
With a couple of Months until delivery, time seems to be going so slow.
Thanks in advance,
Cheers, Glenn
Thanks in advance,
Cheers, Glenn
