Time to fit out the new tug
852
I can't put it off any longer. The old diy layout for the Dmax fitted ok but I need to change things around because the Cannon does not have a long range tank - which means jerries, and jerries need to be easy to fill, which means moving the fridge, and the fridge needs to easy to fill, which means moving the toolbox....sigh. Also the back seat area is a different shape and we now have a dog.
20260602_153536.jpg First test fit. I cut a cardboard template and then off to bunnings to buy some 17mm formply and 12mm basic plywood. My ladder and chairs used to lay on top of everything but will now slide under. I first made it in one piece but it was way to heavy for me to lift and cutting it in half makes it much easier to get in.
20260603_110214.jpgSo far so good. Jerries are easy to access - I'm hoping no one notices me filling them as they are right next to the filler door and I've 3d printed a drip tray that fits in the necks so any spills with run outside the open window. The fridge is fine on the other side - easy to access via the other window. The honda generator is rarely used these days so it will slide all the way back between to fridge and the jerries and sitt over the strong centre supports.
Next job is make custom shape boxes for the jerries etc and figure out how to stop things moving around but easy to slide out if necessary
20,058
In my Colorado I carried Jerry cans (steel fuel, plastic water ) in large plastic HD crates, catch spills in any and didn't need to move them, had always planned to buy a 100lt tank that fitted against the headboard from a mob in Bundy, jury still out regarding Ranger set up as I carry 2 jerries on on back of van..
With a hard lid tub now at least I don;t have to lift full ones, impossible anyway and Im keeping the hard lid set up as its far easier than a canopy to get at things and would only load more junk.
Reactions: jazzeddie1234
852
Yeah my Dmax has a hard lid and it is great for forcing me to think about what to take on trips.
My plan for emptying the jerries is to use my jiggle thing siphon but me being me, I have looked at fitting one of those diesel heater fuel pickup tubes and use a universal fuel pump to drain into a tee fitting on the breather hose....
20,058
I also look at ways not to lift the things up, actually for many, many years now ................... If I have to do a fuel transfer its the jiggle hose, had a small electric fuel pump but slow as a wet week so went back to the jiggler, Jerry's on back of van get jiggled into smaller can for transfer as I cant lift the mungrels out of their racks when full , careful planning means rarely used anyway ............ In the Colorado I could just syphon straight from can in tray into fuel tank, dreamy stuff...
I have cunning plans like that as well @jazzeddie1234, sometimes I carry them out, was wondering if a plastic tank on front of tub and plumbed into tank then I knew I would spill fuel so stuff it..................
Reactions: poor but proud
694
the little 12volt is slow,but these days whos in a hurry?i put that extra juice in when i want to , not when i have to,in the last 10 years i have only had to use my reserve twice,so i not big on carting lots of unnecessary weight , using extra fuel ,for something i very rarely use or need, i have helped other travellers who usually say they have a faulty fuel gauge, but funny i never got paid for that fuel
20,058
West of the Newell Hwy/ Roma sort of thing I will carry the extra fuel otherwise the cans will be empty, see no sense in carting the extra weight though it does depend on the areas Im running through, I may carry one full, did find in Western Victoria it was actually safer to have that extra 20lt, lots of little places down there but fuel stops can be a bit short, especially when the damn wind starts up. Certainly not adding a LRT at the prices they want.
694
694
when we first starting our van life we only went during annual leave.so the weeks leading up to a big trip was all planning,fill everything to capacity car van jerries extra water you know the list. then have to drag it all up the ranges to get out of Brisvagas ,only to find the highway fuel much cheaper and our normal first stops had better water and the small town butchers and bakers were much better price and quality than the supermarkets ,so these day apart form essentals we leave home pretty light
20,058
Its still the case isnt it. We find running off highway everything is cheaper than along the highways, even if a bit more expensive I would still stay off highways.... less hassle..
415
Too true...over the Anzac weekend we headed out to Cania Gorge near Monto...fueled up in Monto for 10c a litre less than in Hervey Bay!
852
Finally fitted the solar onto the canopy after a week of wet days. Shakedown trip next week so a bit of a push to get stuff finalised before the bigger trip to Broome or wherever we end up. I chose the panels purely on dimensions so they sit inside the roof rails
694
very neat,well thought out, do you want to put a canoe on top?
852
Haha no but I do need to transport some long lengths of skirting and I wanted to keep the overall ute height down. Now I can fit a simple cross bar/roof rack when needed on occasion
