I found a cheaper place for the fan
http://www.autobox.com.au/valterra-fridge-cool-fan-caravan-camper-camping-rv
I have never heard of them but nearly 1/2 price
hahaha old age has hit hard today, sorry guysHi,
I must be doing something wrong. Both sites have the fan for $47.50. Both offer free shipping.
Hi,USB Fan with a powerbank, costs about $20
Yep as said, the fan doesn't help with cooling, rather for circulating the cold air internally to help create even temperatures.@Base23 and @Bellbirdweb... do you think I need to get one if we are on the road full time, and in essence shouldn't ever get warm, is it primarily used to cool the fridge down initially? Or do you think it would also benefit long term use?
Thanks.
Thanks.
Found it yesterday as well. Looks like it is the best/only price I'm heading up the the Newcastle caravan show on the weekend so I'll see if I can find one there
Ha ha.... you've inspired me @NoWorries. I have a few USB fans I bought off EBay cheap. I'll hook one up to one of my battery packs and see how long it runs for at work tomorrow. One would hope it would last quite a while.
Budget fan test update: Fan has been running for 8hrs non-stop now on my battery pack. It's still showing full capacity. Plus, I'm keeping cool at my desk.
Would love a pic or two of these fan placements!Just came across this thread about fans inside fridges. Although a bit late, I can definitely recommend it. Just recently had to modify a friend's fridge as his battery operated fan was broken. To replace same was approx $55.00 on ebay. Convinced him to install a small computer fan inside by running a thin wire through the same hole (at back of fridge) as the capillary tube for the thermostat - no drilling!! Only a small computer fan 60mm in diameter was used and attached to wall of fridge (open door side with velcro - no drilling again!!). Had to make a small standoff to allow air to come in from behind. Far cheaper than replacing old battery fan and more efficient too. Has inline switch so can control when required.
My own fridge has two fans inside - 80mm fan at bottom of fridge on side wall facing across the bottom ( no more frozen lettuce!) and moves cold around.
The other one was to combat/reduce the buildup of ice on the evaporator. This is a 60mm fan attached to side wall (again with velcro - no drilling!!) and blows air across the face of the evaporator. Since fitting, have had hardly any ice build up and less need to defrost even in humid weather. Both fans controlled by inline switch. Total power consumption 0.34A. Next step is to include a door switch to turn off fans when door opened. That is another issue.
Hi Mike with the Penguin, The easy answer to the drain tube allowing cold air to escape/let hot air is to make a small loop in drain tube so that there is always a sort of water lock. No air can flow through the water at the bottom of tube and as melt water builds up it allows excess water to flow out but still retains the same level in the bottom of loop. May need to buy some 10mm plastic tubing, but well worth it. Am getting some facts together to place a thread which may be helpful to a lot of followers who have has cooling problems with their fridge. Watch this space. Cheers.
