Got a 1/2 inch hose on the wet & dry vacuum and started a process of flush and suck3 yrs, I do mine every 12 mths, how did you vacuum the tank? just place the nozzle over the hole? or did you make up a smaller tube to fit inside.
How's yours look after 12 months?
We are all guilty of that![]()
No @MDS69 they aren't the heating element they are whats called a sacrificial anode.
Made of zinc, or similar, and are used to protect the tank from rusting.... Same as the small zinc locks you see on outboard motors.
Only way of checking is visual.... Or maybe a leaking tank
Replacement cost around the $18 to $30 mark dependent where you get them.
Ditto!!!!!eep:
But you only do it once![]()
