E
Expanadaman
12' Series
RM2553 Fridge Options
Latest result - checking inside the top inspection vent area, the pipe that comes up from the bottom boiler is rather hot ie 50-60 as...
Jul 21, 2026
Solar
SOLAR PANELS ? IN SERIES OR IN PARALLEL ?
It is a bit squeezy!
Jul 21, 2026
caravans and tugs being weighed
I am waiting for them to hit Hervey Bay too...
Jul 21, 2026
Was sent a Faceache link this morning about checks at Rolleston, doing awareness checks, no fines it seems .... Comments show how many...
Jul 21, 2026
on the idiot box news and facebook ,police in the central Queensland highlands , take Emerald as the centre of that map, are having a...
Jul 21, 2026
E
Expanadaman
12' Series
No worries, thanks for the further info. I'll re fire it up and see how the upper tubes and condensor pipes in and out feel after...
Jul 21, 2026
12' Series
I do not believe it would be the thermostat. Ian advised to feel the piping above the burner (not the burner itself!) which should be...
Jul 21, 2026
Jul 21, 2026
Jul 21, 2026
Jul 20, 2026
Jul 20, 2026
Bum ...................... I see a drip of water dropping from front of van lower trim to ground, close inspection shows its coming...
Jul 20, 2026
Solar
I’m with you @Hitting the road , all this leaves me behind so I prefer to keep it simple. We barely use our air con when in parks, I...
Jul 20, 2026
Solar
I have always been the opposite...more volts to push the amps. I am certainly no expert, but the issue I have read of over and over, is...
Jul 20, 2026
E
Expanadaman
12' Series
Ok, ran it on gas for 4 or 5 hours at flat out, max cool, no cooling in fridge. Then wound thermostat back to minimum to see if flame...
Jul 19, 2026
