Have now fitted the 2000w inverter, fused via a 250A fuse direct to the battery leads at the Busbar connection being the Busbars are...
Feb 20, 2026
Thats why I prefer parrellel on van, short runs so no need for extra volts, I'll take the Amps .............................. Using...
Feb 20, 2026
Good to hear your new tug is meeting expectations...8-)
Feb 20, 2026
Feb 20, 2026
Feb 19, 2026
It's all about WATTS Ian. 5.4 amps at 36 volts amounts to approx 194 watts, while 5.4 amps at 18 volts amounts to only half the total...
Feb 19, 2026
Another Dunny Idea ...............
Some camps weve been at nearest dunny could be 50 miles or more away and then some you don't want to get out of the car let alone walk...
Feb 18, 2026
Not a real bad idea if you spend a lot of time off grid where there are no Dump points...for the girls anyway...quite a few vanner's are...
Feb 18, 2026
The only problem twos are the ones that refuse to exit after multiple flushes and a queue of dumpsters cheering on :oops:
Feb 18, 2026
Feb 17, 2026
Feb 17, 2026
Thetford now has a separation toilet, while its not a compost job it doesn't need water flushing, you have a wee bucket and a big Doggy...
Feb 17, 2026
Feb 15, 2026
Starlink Mini ideas.....
More plan changes, you can now get a Gen 3 Standard unit for free, well no rental or purchase required with a 3 tier plan set up...
Feb 15, 2026
