BaldEd's post
17' Series
Setec Unit
Drover: So true. When my Jayco arrived from the factory, my memory may have dimmed a little since, but I seem to recall that only 2 or 3...
Dec 9, 2025
17' Series
Setec Unit
Many have fitted better BMS units to charge their batteries especially for AGM's and Lithiums but they kept the Setek unit as the 12v...
Dec 9, 2025
BaldEd's post
17' Series
Setec Unit
The SETEC ST35 III unit that came with my 2016 Jayco has 3 functions 1. It has a 240V AC input lead that passes power to a stepdown...
Dec 9, 2025
17' Series
Setec Unit
@BaldEd has described it exactly ............................... So if you have fitted a better charger to your rig then just leave...
Dec 9, 2025
17' Series
Setec Unit
Dec 9, 2025
BaldEd's post
17' Series
Setec Unit
Dec 9, 2025
B
BaldEd
17' Series
Setec Unit
Dec 9, 2025
17' Series
Setec Unit
Thanks for the replies men. If I were to unplug the 240plug that is connected to the Setec, are you saying even then if I were plugged...
Dec 8, 2025
17' Series
Setec Unit
Dec 8, 2025
17' Series
Setec Unit
Don't forget @garfield28 that the Setec also acts as a power distribution device for all the 12 volt power circuits. Although you may...
Dec 8, 2025
17' Series
Setec Unit
Thanks for the replies. If I remove the Setec unit does that mean that all of my lights can only run off 12V power even when I am...
Dec 8, 2025
B
BaldEd
17' Series
Setec Unit
Dec 8, 2025
17' Series
Setec Unit
Hi all, I am pulling out my setec Unit as I do not use the battery charging aspect of it, so it has no use other than that. My...
Dec 7, 2025
I sold my boat to cover things, the Jeeps turbo had a fault which only showed itself when towing, 30kms and into limp mode, the fix...
Dec 7, 2025
With the new capacitor the fans fire up and then drop off momentarily and you can here the compressor try to start but jut gives a click...
Dec 7, 2025
