Mikedebs
NSW - For Sale
2004 Expanda 16.49.3 parts
Hi Chartrock, Thanks for your interest in the project. Please see below before and after pics, with layout graphic. Hopefully self...
Sep 16, 2025
Suburban hotwater unit wont run unless door is open.
Hmmn. Running out of options now @Sparksy. Strange that gas supply remains full ON when door is open, but slowly diminishes when door is...
Sep 16, 2025
S
Sparksy
The gas switch isolates all power so board etc is isolated when gas is switched off. Ive got hold of another board but doubt its...
Sep 16, 2025
Off Road or Not
He can’t answer you until he has 5 approved posts although one of the posts could be answer which would probably be approved. However he...
Sep 14, 2025
Off Road or Not
Love
@chartrock and @Boots in Action hence my quote above .................................. two can play at that...
Sep 14, 2025
I thought it was a thermocouple, either way the prongs send a current to keep the solenoid open, looked in my manual and the prongs...
Sep 14, 2025
A good thing to rule out though. I have heard of a few cases where it was a problem with the regulator
Sep 13, 2025
Off Road or Not
Hi @chartrock , it is great that someone is monitoring some of these "way out suggestions" on behalf of Members. Personally, I think...
Sep 13, 2025
Off Road or Not
Hi @Drover, this guy is a newbie and is proposing to start discussions on fairly meaningless topics. He has proposed at least 5 subjects...
Sep 13, 2025
Off Road or Not
I'll bite .................................................... Mine runs on solar/battery which runs everything bar the fridge and HWS...
Sep 13, 2025
Thanks @Sparksy for that info and the fact that the Suburban hot water system does NOT use a thermocouple to keep gas valve open...
Sep 13, 2025
S
Sparksy
Thanks. But the suburban hot water doesnt use a thermocouple to hold the flame failure solenoid for gas flow. I can see your point but...
Sep 13, 2025
I dismantled the level indicator and other rubbish years ago, just pulled it all out and binned it, so the solenoid is all thats left...
Sep 13, 2025
Sparksy's post
After a incident where the solenoid jammed open , I fitted a isolating valve in the supply water line under the floor. On a side note ...
Sep 13, 2025
Well the Flood Alarm went off today, as the tide started to lap at my feet, the flush button on Dunny had jammed, quick race outside...
Sep 13, 2025
