S
Sparksy
Suburban hotwater unit wont run unless door is open.
Been away for past 3 weeks, some of which was offgrid. When running the hot water on gas i have a issue where the Suburban hot water...
Sep 3, 2025
Starcraft
the dreaded 5min suburban hws maintenance
I am a leave the tanks full when parked up person...I usually either totally empty them and refill when I get back, or before leaving...
Sep 2, 2025
Mikedebs
NSW - For Sale
2004 Expanda 16.49.3 parts
Hi Chartrock. Thanks for your interest. Had been looking for a long time, but could not find an outback (off-grid) 2 person tourer...
Sep 2, 2025
Starcraft
Sep 2, 2025
Starcraft
Need to paint the PRV red so I remember to release before I pull out the anode ... I wasn't aware of that the first time I changed the...
Sep 1, 2025
Starcraft
Sep 1, 2025
Starcraft
The CV has been idle in the drive for 12 months so I clean forgot to check the anode...which was a stub when it came out. I never used...
Sep 1, 2025
Starcraft
Yep, the 5min anode change turned into a 3 hour project as the new anode thread would not bite no matter how many times I tried. Ended...
Sep 1, 2025
Starcraft
Sep 1, 2025
Starcraft
I have a wire bottle brush which does a grand job on the threads, did have similar happen once and when I stuck a probe inside and then...
Sep 1, 2025
Starcraft
Aug 31, 2025
Starcraft
All Other Jayco Discussions (Non Expanda)
Aug 31, 2025
malakai
16' Series
Setec ST35 11,
Thanks again drover,ive since found the cause of the outside light and now works ok.
Aug 30, 2025
malakai
16' Series
Setec ST35 11,
Aug 30, 2025
malakai
16' Series
Setec ST35 11,
Hello to all, I'm currently doing a litheum battery change from my old agm and st35 Charger. Im now doing the fusebox wiring,and even...
Aug 29, 2025
