You are right Drover...I did some further research and found that by connecting 2 strings of panels connected in series, the MPPT will...
May 15, 2025
Of course I forgot you had split it all up .............. I'm probably wrong but I think if you have 2 separate strings in series...
May 15, 2025
Yeah, the BMPRO BMS in my setup is purely a distribution / fuse point as it is only good for 300w or 20 amps solar input anyway...the...
May 15, 2025
Just adding, I was seeing 43v - 44v at the MPPT with the two roof panels in series which I was reasonably happy with, even though the...
May 14, 2025
May 14, 2025
Never a great fan of BMPro units, if you went series with your panels that might be your problem as its chopping the voltage (most seem...
May 13, 2025
Just got back from 8 nights off grid...very happy with the 2 new 200w panels I put on the roof. Where the old 160w panel did very...
May 12, 2025
May 12, 2025
May 11, 2025
Its amazing really, years of stuff ups the lessons have sunk in ................................. better write them down before they...
May 11, 2025
May 10, 2025
May 10, 2025
Ian, I believe you are all over it!! Great stuff!
May 10, 2025
@Boots in Action , since I had to do the Lithium set up manually for mine, its all programmed to shut off at 0c, with other settings...
May 10, 2025
Well I found a Utube vid on my Kings 120ah Lithium and it seems I have chosen well, which is a good thing, mine has been running very...
May 9, 2025
