Chassis
Forgive me Father for I have sinned...
Didn't look like anything wrong with the backing plate, when they need replacing they really look like it ............ if you do...
Feb 21, 2025
Chassis
Yeah I had repacked that one already and fitted new seal ready to go back on... Pulled right front, linings between 4mm & 5mm. Bearings...
Feb 20, 2025
Chassis
Wow that grease looks perfect compared to the state of mine which was pretty black!
Feb 20, 2025
J
JamesW
Starcraft
Camec Santoprene door seal
All Other Jayco Discussions (Non Expanda)
I have a 5mt length of the subject door seal. The outer door has it installed. There is a track for it in the inner door frame that can...
Feb 19, 2025
Chassis
I think thats after the repack................... When the hand brake doesn't hold then you know, lol,lol...
Feb 18, 2025
Chassis
Feb 18, 2025
Chassis
Pulled the first hub today for the bearing clean & pack and brake lining replacement if needed. The outside bearing was getting light on...
Feb 18, 2025
Chassis
I have put that LF back on with the linings as they were, I am about to pull the RF, see what that one looks like. If it is down any...
Feb 18, 2025
J
Jared01
Thetford N504 not turning on via car 12v
Thanks very much for the detailed response! I will see if I can check further and will reply with the outcome
Feb 18, 2025
J
Jared01
Hello, I am trying to investigate a problem where my Thetford N504 fridge is no longer turning on via 12v from the car. Caravan a...
Feb 18, 2025
Chassis
Just following up, does anybody have any idea how much depth is in the standard brake lining? I have measured mine as above, (Alko), and...
Feb 17, 2025
Chassis
Feb 17, 2025
Chassis
If you can click your fingernail over them then yep chuck them, with a van or even a car I wold probably chuck 'em, as above, getting OS...
Feb 8, 2025
Chassis
You blokes use the same method as I do...I have always after refitting tightened the axle nut until the hub is difficult to turn to seat...
Feb 7, 2025
Chassis
Feb 7, 2025
