Chassis
Forgive me Father for I have sinned...
Just following up, does anybody have any idea how much depth is in the standard brake lining? I have measured mine as above, (Alko), and...
Feb 17, 2025
Chassis
Pulled the first hub today for the bearing clean & pack and brake lining replacement if needed. The outside bearing was getting light on...
Feb 17, 2025
Chassis
If you can click your fingernail over them then yep chuck them, with a van or even a car I wold probably chuck 'em, as above, getting OS...
Feb 8, 2025
Chassis
You blokes use the same method as I do...I have always after refitting tightened the axle nut until the hub is difficult to turn to seat...
Feb 7, 2025
Chassis
Feb 7, 2025
Chassis
I go full tight then back off to bed the bearing and grease then back off to do a few spins before final tension, then the bearing...
Feb 7, 2025
Chassis
I set my bearing preload with a spanner to just on where it feels tight and then back off to the first hole for the pin. The ute on the...
Feb 7, 2025
Chassis
If done properly should last the life of van or longer, Big Mals are 13 yrs old and when cleaned up spin smoothly so get repacked and...
Feb 7, 2025
Chassis
The drums are quite scored on mine so wasn't sure if they could be be machined at a reasonable cost compared to new.
Feb 7, 2025
Chassis
Feb 7, 2025
Chassis
Feb 7, 2025
Chassis
Hmmm...I gotta do the wheel bearings in my van over the next few weeks too. The last time I had them out, cleaned and greased them, was...
Feb 7, 2025
Chassis
...it's been 3 years of trips since my last bearing service :o 2 down, 2 to go. Bearings look ok but the grease didn't have another...
Feb 7, 2025
Interior
Hot water system
The simplest setup I've used is a hot water bag placed on the edge of the rolled out awning and the shower tent under that. The 12v...
Feb 6, 2025
Interior
Hot water system
I had one for about 2 camping trips before selling it and going back to the trusty 5l pressure sprayer painted black. To much hassle to...
Feb 6, 2025
