Finally got out last week end for a pre test of the new tug (Ranger mk2) with the expanda to a free sight
Toorongo falls Ranger whent well towing the camp site was awesome camp fire pits only draw back if you don't have a dunnie on board they have drop loos so yes you need to be equipped for free camping.
The walks to the falls are a bit steep if you take the long way around 1.5 hr its an easy walk.
So back to pre xmas maintenance as I like to tinker with my van and fix the little things rather than pay at service
List of things i had to fix
Door lock came out when locking door re inserted lock
Side locker door lock jamed (WD40) will help here
Under van check found hose clamps broken replaced
Along with usal checks tyer pressure wheel berings
Park brake and brake away battery check deep cycle battery
Lights in and out and even the hitch gets checked
Gas tank full and hoses and fittings checked
Most inportant smoke alarm battery and fire extinguisher charged.
If you aren't comfortable doing these checks get your local dealer to check these
As they should do this in a saftey check
If not they should
Im sure others have more equipment they have to check but this is my basic check list i like to check before a long trip and at silly season im dont want to risk my families safety on something that takes a look to see if its ok.
If not they should
