Thanks, my name is Jim.  I'm new to forums etc.  On winding down my Jayco Swift got it down to about 45cm from completion, then would not lower further.  would wind it up wind it down,  nothing! .  Finally had to take off the ply wood pannel from inside camper in line with the cranking hole.  With winch and cables exposed I found the cable caught on a cuphead  bolthead !!  Yes so small  on the inside of the the winder spool.  I wound up the crank handle and and applied small pressure to cable.  With multi grips I pulled the cable off the cup head and with wife winding the camper up again I re positioned the cable on the spool  to run straight and not bunch up on the side of spool.  I applied grease to the cup head and gear teeth   So far as good it works..  I hope this helps if anyone else can't lower their  camper fully
