Where do you store your Stone Stomper?
megcam
Hi All
As the title suggests I'm looking for some creativity on where to store the Hayman Reece hitch with Stone Stomper bar attached. It seems to be in the way every where I put it.
p.s. yes storing it on the car with the van attached while jaunting around the country side is my preferred method too :D so just looking for ideas when earning a living keeps you at home
MickL
66
115
SA
I had pretty much the same thought process as you and couldn't come up with anything so I just undid the two bolts and removed the cross bar from my HR hitch. That way I can stand the cross bar up or lay it on a shelf in the shelf and chuck the hitch on the ground under the shed. I figure it only takes 2 minutes to re attach it when I need to use it...
MDS69
733
803
I have two hitches. The first has the 50mm ball and the second has the Stone Stomper bar and Treg coupling. The second one stands up on its end in the garage when not in use.
