Electrical What are these wires for?
RV80
13
4
As the title says, does anyone know what these two wires are for?
Doug
52
50
Leeming / Perth
Where abouts in the van is this pic taken from? What model Jayco have you got. The word Trans would refer to transformer I would think in which case they would be active and neutral from mains but that wouldn't be right because they should be brown and blue.
RV80
13
4
They went into the original charger, but everything still works without them. There is no power from them.
20,038
At a guess power form the tug ??? Bit more info on what youvé done, type of connection from tug etc otherwise not much help as the van is full of white and black power cables and as far as I recall AUX is power in from external 12v, namely car. The AUX cnx doesn't appear in the manual.
20,038
Was the Setec broken ?? or just wasn't doing the job you wanted ???
Expensive bit of kit.
or Transgender
@RV80 if you are wanting serious answers to your criptic questions, you may help a little with some clues
4 Across - white and black cable marked "TRANS"
7 Down - it came from a setec that was taken out
14 Across - I wanted to change it
damn hard to really help - sorry
how about,
I have a "...(insert size and type of Van)...." that, when I changed the Setec out with a Redarc one, I found these two cables............
they were previously plugged into the Setec at "...(position)..." but I have not connected them up to the Redarc, as there is nowhere to plug them into
could they be important........??????
Reactions: Drover and Doug
