Hi there . We have an 06 expandaans we would like to change over one of the brackets from a 4 to a 9 . Is this possible . Seems a 9kg is to high under the pull down front bed?
Do a measure you may be able to mount a bracket inside the draw bar but mounted at the bottom of the bar, I wouldn't weld on the draw bar but make up a bracket that uses U bolts to fit the draw bar, then you don't compromise the integrity of the bar..........
