Yes it does, but with the added gas seal taper inside.Looks like a Nitto air fitting.........
I have the same length of braided bayonet gas line. I found because it cant rotate when its permanently attached to the BBQ, constant use is causing it to crimp, and loose its shape. For that reason I dont leave the hose attached anymore, so thats where I thought this would solve that issueGood idea, I just got a 3 meter gas hose which replaced the orig Webber hose. Stays on Webber all the time and I just wrap it around the base when not in use. Other end is bayonet so just plug it in when needed.
I think if you had a few of the above quick release fittings on what you needed then you could chop and change as needed so great idea!
I showed the Princess that. Her suggestion was you clearly didn't cast your net very wide
I got mine through https://www.ebay.com.au/usr/ozcampingclubI have been using these for a few years now and a good bit of gear and easier than the bayonets.
Crusty, have you got an ebay link to the supplier.
Unfortunately I wasnt previously aware @Ligedy sold them. His ebay page is https://www.ebay.com.au/usr/ligedyletch
The quick connector is not a Nitto air fitting, its a gas variant that resembles the Nitto air. The quick connector I purchased is made by gas fitting supplier Aquaknect in Sydney, the same gas fitting supplier of Ligedy's gas bayonet fitting kit so its as safe a path as any to take if you want to add the flexibilityI went into these very thoroughly..great idea I rang about using the nitto air fitting..and it was explained it wasnt gas rated..I then thought of the number of gas bottles you hear about exploding..so I thought not a good idea if you get a slight leak..went with @Ligedy bayonet kit which was good quality..priced the parts myself and just wasnt worth the running around for the little extra he charges. My weber hose is a pain to put on ..so these sound like an easy solution.I always remove my hose.but it puts strain on outlet doing so.
message @LigedyThis looks awesome. What type of hose do I need and where to get them please?
Fitted mine on the weekend, much better solutionDo you sell these @Ligedy
I would be thinking of getting 1 barb for the Webber and 2 x quick connectors for each of my hoses (1 x Jayco Webber bayonet and 1 x traditional Gas bottle connector)
Did you find anywhere that sells just the quick connect end? I only need 1 x barb, but 2 x quick connect ends (if that makes sense) as I use a bottle at home and the bayonet hose on the van.Fitted mine on the weekend, much better solution
I wasnt looking. I didnt see any single ends but i assume they are supplied as pairs. You could try asking Aquaknect in Sydney if thats an option, at least youll know before searching about. If it is an option maybe @Ligedy can source them or at least you can find out who canDid you find anywhere that sells just the quick connect end? I only need 1 x barb, but 2 x quick connect ends (if that makes sense) as I use a bottle at home and the bayonet hose on the van.
