Water Pump Issue
Mick_309
80
61
Noosaville
Hi All, hoping for some advice.
My water pump is not holding pressure and when on water is coming out of the mains hose input. I have checked all of the lines and clamps and it all seem air tight. Could it be a non return valve issue? I have a 2013 20.63.1 OB
Thanks in advance
Mick
19,651
Yep, inside the plastic bit where you hook the mains onto is a NRV, just remove the fitting and pull the NRV out of it and put the fitting back in place and add a George Guest NRV in the line just down from the fitting that will fix the problem, removing the faulty bits will mean it won't restrict flow........Guest NRV is about $15.
Reactions: Mick_309
Dogger
48
87
Wallerawang
I had issues with mine sticking causing me to have no mains pressure so I put some Vaseline on the non return valve rubbers and now it works like a treat every time
19,651
....Handy Hint #69.......If happens when on the road, and using your tanks then just connect hose to mains fill and other end to tap on draw bar with tap turned off then no water leak and pressure good...........then you can fix at your leisure.
Reactions: jeff
