I know this makes me sound like a dummy but I'll just admit to it upfront.
When I use my water pump in our 17.56 a lot of water is lost through a metal piece in the hose connections under the van. This part of the hose connections is approx 125mm, has 2 small holes in it through which the water appears to overflow and trickle to the ground.
The pump if it is a pump is stamped HEFLEX (?).
I googled it and also tried the jayco website but obviously had no success as here I am.
Can an expert please tell me what it is and what it does.
Can it be fixed or does it have to be replaced.
Seeing all your precious water end up on the ground when you are free camping could turn a man to drink!
John
John
