Hole in floor ready for air pump
pump installed to floor
outside view
Switch for pump fitted
Ducting for pump installed. Limited places to fit in the 14.44 so used area under seat
Outlet into van
Filter installed. Stone shield still to be fitted to prevent filter being damaged.
Temp blanking plate for Dual fans fitted for heat extraction from fridge. If works well will make more permenant solution.
On/Off switch for fridge fans.
