Hello,
I have a 3 year old Jayco Starcraft 17.58-3 Outback running on the original Ritar 100AH SLA Gel battery.
We have the original 120W Jayco installed solar panel on the roof, other panels installed, standard TPS 1230 solar controller, Setec ST35-III and no compressor fridge (just the standard 3-way fridge which is good enough for us).
About 2 years ago, we installed a diesel heater and sometimes we get down to 12.2v in the morning after use of the heater overnight.
I have been thinking about swapping out the Gel battery and replacing with a 100AH (or possibly 120/130/150 AH) lithium LifePo4 battery.
I have also been thinking about getting a portable solar panel as well as swapping out the TPS 1230 and installing a Victron MPPT 100/30.
Whilst I am just becoming familiar with the lithium technology, I have a few questions if anyone may be able provide assistance.
- Can I just swapout the SLA Gel battery and replace with a lithium battery such as a 100AH LifePo4 battery?
- I believe the Setec ST35-III only outputs 13.65DC (at 35A to charge battery/power connected loads). Will that be may not be high enough to fully charge the lithium battery and or could it reduce the lifespan of the battery overtime?
- Is the above 13.65DC 35A the same output when the Setec is powered from 12v by the car and 240v when powered by mains?
If the Setec is not suitable, I am not sure if I need to re-wire a lot of things if itis replaced, or if I can just disconnect the charging circuit, install a DC-to-DC charger connected to the car 12v, possibly same DC-to-DC charger can be connected to 240v (so battery is chargeable when onsite), maybe have an inbuilt solar controller too otherwise install something like the Victron MPPT 100/30 and be done with it?
Has anyone done something similar?
