tv wall brackets ??
rcf
Gladstone Qld
Has anyone mounted a tv bracket in the double bed end for the kids. Any pics info/ideas would be great thanks.
Soaring
998
1,249
Melbourne - Eltham
13,974
Jayco ply is very thin and very poor quality. Much better suited to weight reduction than hanging things off. @Soaring has the right idea in his links above, in that you should bolt through the ply to a plate on the other side. The screws will likely pull out if screwed just into the ply with a tv bouncing on them
Petenlou
27
Heyfield
I thinking of Hanging a TV mount from the Storage Cupboard where the Small Bench is
Question is how much Weight can this Storage Cupboard can hold
How is this Cupboard fixed can see any screws,Bolts ETC
Soaring
998
1,249
Melbourne - Eltham
@Petenlou that was my initial plan, but the bracket I bought was too big to fit under there. The curtain pelmet takes up a lot of the space there.
That's why I opted for the end cupboard instead.
Reactions: Crusty181
Petenlou
27
Heyfield
Looks great i just had a look in our van and there are 3 Screws holding the Cupboard to the Metal frame around the inside of the van
Where did you get your mount from
Thanks for bringing up this post again guys and @Soaring for for your pic (Knew I'd seen it somewhere before).
Unfortunately our TV is 29" and not confident hanging it under the overhead cupboard and too big to fit under the end cupboard (Want to strap it and leave in situ when traveling).
Going to research ceiling brackets and maybe reverse it and fix to the top of the TV bench.
Getting lazy in my old age and looking for less things to setup once we stop ;)
