TV signal from caravan park instead of van antenna
cancan
231
Manly; Brisbane
We have the wind up antenna for our tv signal but it is crap where we are but then there is TV out let in the power box at the caravan park so I have run a lead to the TV inlet on the side of the van but my problem is how do I switch to this as there is only 1 TV outlet by the tv
7,469
Cancan, when I have had this setup I just run the lead from the power box through the top window in the pop up part of the van (they are only velcroed on) and straight down to the back of the tv.
cancan
231
Manly; Brisbane
Thanks Chartrock but I have a full size van although I might run the lead through the back door and just check that it does improve the reception.
Roh
49
6
Mornington Peninsula VIC
Hey cancan
I was under the impression that if you turned the booster switch off( little black button on tv plate) then it switches to get signal from the outside tv socket. Never tried it so good luck
Roh
3,060
2,345
Like wise, also did this with the camper, just ran it under the canvas at the bed end. but if using the TV inlet from park power box, turn off the wind up aerial booster, remember some areas may not be Digital yet so auto tune is the go.
cruza driver
Hercules
6,551
4,450
Mighty Victoria
Well there you go I never knew that :hail: about the booster switch.
I have only done it once at Bright and ran the cable up under the canvas at the bed.
gspy4u
235
112
Ipswich
yep same with ours, turn booster off, antenna plugged into side of van and you get that signal.
MBC004
48
51
I am having the same issue but when turned off i do not get any signal inside my van
Any other ideas
